Split Walls and Columns
Split multi-storey walls and structural columns at any combination of project levels. Choose your target levels from a visual list and apply with a single click.
Automate structural element splitting in Revit.
The Challenge
During the conceptual and early design stages, Revit models often contain walls, columns, beams, and floors that extend across multiple storeys or span several grid intersections. While this approach is ideal for rapid model development, these elements typically need to be split as the design progresses.
On medium and large projects, manually splitting walls, columns and framing can consume several hours per revision cycle, introducing inconsistencies and reducing valuable modelling time.
The Solution
Split Structure is a Revit add-in that automates element splitting in seconds. Select your elements, choose your levels or intersection points, and click Split. The add-in handles the rest, preserving family types, data, level constraints, and offsets throughout.
Divide floor slabs along selected grid lines or named reference planes into separate regions, ideal for phasing, RC Detailing, structural analysis export, and coordination.
Automatically split structural framing at every column centreline intersection. Works across the whole model or on a user-defined selection of beams and columns.
What takes an hour manually takes seconds. Free your technicians for higher-value work. Model Quality You Can Trust.
Level constraints, base/top offsets, and family symbols are preserved automatically, no rework. Works on Your Whole Model or a Selection. Process every element at once or be surgical. Your choice.
Compatible with Autodesk Revit 2024 - 2026. Supports steel, timber. concrete, and composite structural families. Works with both structural and architectural column categories.
The software solutions available through Naviate Tech Preview are provided free of charge and should be considered experimental. While we strive to deliver useful tools, they are still under development and may contain known or unknown issues.
We strongly recommend that you:
If you encounter any issues, we encourage you to report them to us.
Please be aware that these solutions may be updated, modified, or discontinued at any time. Some may evolve into official Naviate features in the future - while others may not.
